brake clean works
krowbar
8:56 AM
979 Texas
What do you clean you grimey tires with? I tried brake cleaner in spray can and that **** takes off ALL the funky stuff FAST and no scrubbing.
Dawn detergent works and is probably cheaper, but if you like the Brake cleaner, thats fine too.
Tires or rims? Usually I just whip out the old power washer for the tires. :glasses9:
This is what I keep around for cleaning tires. Use it on farm machinery too. Spay it on and wash off.
Or this..
Brake clean is really handy for cleaning lots of different stuff. I've used it as a degreaser for cleaning up small areas on engines etc. I've also used it for cleaning electrical connections when I'm out of electronics cleaner with good results.
carefull about using brake clean on any rubber items.it will pull all the oils out of the rubber and you will have dry cracking in a short period of time.
