SOLD 8 3/4 sure grip center
wollfen
11:12 AM
Greenville NC
Feedback: 1 / 0 / 0
I have a 741 case suregrip with 3.23 gears, the sure grip still does its job and the bearings are good too but the crown wheel has some rust pitting on a few of the teeth, Id like 300 for the unit. It weighs about 80 pounds packed and i believe Fedex ground is cheapest to freight by. my zip code is 27858, cheers,
Gary
would you take $250 since it is pitted and i will drive down from Va to pick it up
Hi scott yes it is, check the teeth in this picture as well, cheers.suregrip1.jpg
The sure grip center itself is simply bolted to the crown wheel and the side bearings should be the same for all 8 3/4 sure grips? A quick check of the bearing part numbers in a parts catalog should be able to confirm this.
