Turn the engine to TDC on cylinder 1 on the power stroke. Pull the distributor out and take a large flat head screw driver and stick it in the slot, turn it (clockwise iirc) so that the oil pump shaft will drive itself up off of the cam gear. Turn it further back to get the slot oriented whatever way you need to set the distributor to number 1, and turn it back so that the gears mesh back together and it fits back correctly. Reinstall your distributor and set to fire number 1.
GMX,
To got TDC on the power-stroke, one would have to line up the timing marks on the harmonic balancer and the the center line on the timing cover right?
Provided the engine has not turned since you pulled the old distributor - then yes is the answer![]()
KiwiGTXs question was just to make sure you don't wind up 180 degrees out on the distributor. TDC on the timing tab can be TDC on the power stroke or TDC on the intake stroke. Make sure the rotor points to number one with the balancer/timing tab at 0 and youre good.
And yes, they should have done this last time with the Mallory distributor
If the engine is at TDC in that picture your problem is just that the oil pump drive is in wrong (not that it matters from a mechanical standpoint but from the standpoint of the vacuum advance can fitting where it should). At TDC the slot in the drive should be perpendicular to the crank. Give that a shot and see if it works for you.
Are you sure you have a handle on what they are meaning by the power stroke? This is very important, If not there are a few ways of checking it. Have someone rotate the motor while you hold your thumb over the #1 spark plug hole, when you feel it start to blow your thumb off of the hole it's starting up the compression stroke (power stroke), now turn it to TDC. If working alone take the valve cover for #1 off and watch the rockers on #1, they will both be closed as it approach's TDC if on the compression stroke if the exhaust is open then it's the "exhaust stroke" go another full turn.
Did you set it at TDC? if so your hearing pinging most likely and need to back it off. 12-18 BTC is a starting point, Sorry for any confusion but when referring to TDC it isn't meant to set timing there you just need to no your on the compression stroke and on your timing mark BTC(whatever it was). Turn it back and you should be fine.747Mopar,
I performed the listed steps and felt for the compression stoke. I hooked everything back up and now have quite a bit of lifter/valve noise. The engine runs, but did I over do it? Not too sure why I have a knocking noise in there now.......
sorry i came in late in this thread,but for future reference there is a simple way to solve your problem.if you have a running eng but the vac can is hitting something,all you need to do is rotate all the plug wires at the cap 1 space each towards the item it is hitting.just be carefull to keep you firing order and time from there.it will clock the distrib about 45 degrees further up and alow for vac can movement while timming.
