YY1
Update-
Two weeks ago, me and another friend helped my brother put PUI covers on his 66 sat.
Was not as difficult as I expected. We also replaced the foam.
Look was good, fit was good except there was a lot of extra room at the top corners.
So much so that we wondered if the Charger buckets he had might be different than Satellite buckets.
Other than that, which we filled with extra foam, and a few wrinkles which we hope will smooth out with a few heat cycles, they look good.
I went a head and used a discount code found here! and got Legendary covers from Classic.
Last week, I did the top of the back seat, and it came out pretty good, again with just a few wrinkles I think will come out with a heat cycle.
The Legendary does appear to have a bit softer feel and thicker padding, but that might be dif between 66 and 73/74 design. I did not use new foam, as what I had was 99% good.
Magnes- those do look good. how did you go about working out the wrinkles?
With the discount code my order for both fronts and the back was about $520 including shipping.
