Hydraulic Roller Push Rod Length?
robinsonwr
6:38 AM
Carriere, ms
OK, I know some of you guys are running hydraulic roller camshafts in the RB engines. I also know they are measured for the application. I just would like to know what length worked on your combination? I will be measuring for mine shortly to order from Smith Bros.
I just ordered Mine from them a few weeks ago. Mine were 8 5/8's end to end. This was with a Indy grind cam and crane lifters and gold roller rockers. This was with EZ1 heads though. With stock heads I think they were almost a halrf in shorter.
all depends on the base circle of the camshaft, how much has been milled off the block deck & heads mating surfaces or what heads & how thick of head gaskets you use & the style/make rockers your using/type of adjusters etc.... what works with my combo isn't going to be the same as what you need probably.... mine are 0.125" over stock B spec. w/a custom grind hyd. roller @ 7.625" O.A.L. 5/16" cup & ball 3/8" molly Smith Brothers push-rods, with 0.120" 11/32 lash caps for a 383/479ci B-series Low Deck Block {Crane says 7.5" std. for B-series Low deck, for the std. base circle Crane Hyd. Roller, with Crane retrofit hyd. roller lifters & Crane Super Gold 1.5:1 or 1.6:1 roller rockers, but they wouldn't work with mine}... you really need to check them no matter what, with the lifter fully pumped up & proper lifter pre-load, even if you have a nearly exact combo to someone else's period... good luck
do you want some spare gold crane rockers?
you will brake them with a roller cam.
ask me how I know broke 6 before I went to Harland sharp
67Steve you gotta have coil bind or something causing them to break.
yeah something's up or wrong, I would guess... I've ran them for years in a variety of race & street engines with solid, hydr. & full on radical race rollers both hydr. & solid configurations, some on combos up-to 1800hp Blown Inj. Alky & spun into the 8500rpm with near 0.800" gross valve lift range, with 1.6:1-1.7:1 ratios & I never had any Crane Super Gold Roller Rockers break/failures, as long as you have adequate oil & the proper set-up &/or clearances... I've had adjuster screws break & bend a few pushrods etc. but never a Rocker Break/failure...
Just out of curiosity, my morbid brain needs info...LOL... what happened to make them fail ?? that's the bigger question... I've had the roller trunnions fail on Harland Sharp rockers from a defect too, little roller pins on the shaft grind up/disintegrate & go thru the motor {most was caught in the System One/O-berg filter screen fortunately} & screwed everything up on the top end too, so any rocker even a high $$$ set of roller rocker "could possibly fail", in some way or other... But actually "breaking" a shaft style rocker, let alone 6 of them, you had to have something that was "really wrong" coil bind or the camshaft grenade or rocker stuck on the shaft, because of lack of oil or something catastrophic, to cause a failure like that, with any shaft style rocker....
Q; did you do a bunch of grinding/machining on them for valve spring clearances ??
possibly weakening them in a critical fulcrum area near the shaft
I had my block decked,heads milled, .039 head gasket, lunati hydraulic roller and hughes 1.6 roller rockers. I bought smith bros. 3/8x .083 5/32 cup 3/16 ball 7.975 legnth.
