S.I. Coronet
What are the differences, interior, body, ETC???
74 has-
integrated shoulder belts
different rear panels for above
I'm sure there's more
metall frame parts prepaired for that ( roof and quarter area behind rear plastic panel )
pressed in ball joints just on lowers... this makes also a diff LCA.
for 74s ( based on my Chargers experience ):
gas tank straps and J bolts fits reversed on 74s, hooking on rear, bolting in front
dunno on Plymouths, but Chargers got diff lower brackets setup for rear bumper guards.
firewall hole for steering column and its bracket totally diff
steering column shaft diff
cowl panel with hole for washer nozzles hose connector
firewall with couple of holes for interlock resset button
underdash, engine and forward lighting harnesses unique for 74s
one common buzzer for all warning buzzing function, instead one diff for every function and controled by the interlock unit control.
horn relay without the key in buzzer function ( just 3 prongs )... moved to the common warning buzzer as explained above.
diff column bracket using 2 attaching points to dash frane area... earliers uses 3 with an extended bracket
diff coat hooks
somewhere in 74 prodction the T handle on floor shifters changed to the round knob.
icons on clusters for lights and wipers
diff three spoke steering wheels ( padded )
In addition to the above I think the front spring bushings are different for the rear leaf springs
The 74's came with coolant recovery systems - diff radiator cap
The 74 data book says "Movable rear quarter windows are included on Satellite Coupe and Road Runner", but I don't think that one is correct.
The rear lower quarter panel covers are different also. The 73's are one piece while the 74's are two piece to accommodate the shoulder belt retractor.
true forgot that!, ALTHOUTH lot of ppl claims 74s got elongated front eye bushings, my 74 got same round front eye bushing with just a THICKER ISOLATOR BUSHING, using an smaller hole for the bolt, smaller bolt thickness and of course diff hanger with just the smaller hole difference to match the bolt assembly
Pic attached showing the minimal diff on bushing thickness and isolation I found but still being round eye, smaller inner diameter but same outer diameter... sorry the bad quality pic, cheap cell phone back in the days. Mounted earliers once by mistake, then I found the one what matches my 74 hanger and bolt, ( left one ) and replaced.
dunno if thats a diff on Plymouths. Not on Dodges though
that's a VIN and option diff not really a year diff
already stated on first as rear panel defference for seatbelt assembly.
here the pic showing this:
strange that 74 Plymouth would use an elongated front spring eye. my 74 charger is round, built nov 9 73. maybe the leaf pack had something to with it? I have 7 on both sides.
