CalTracs and Sliders
eddieb
1:38 AM
Bad Axe
Any of you guys running them on your car ,looking at putting them on my 69 roadrunner. Want to improve the 60 ft. Did they change your ride height? I already have the cals and mono leaf springs and their shocks front and back.
THANKS EDDIE B
i have caltracs and sliders on my dart. they will lower it slightly because your physically moving the rear of the spring closer to the frame rail. will you see a change in your 60ft? not sure because i did the caltracs and the sliders at the same time so i cannot comment. do they work, my car consistently does 1.44-1.45 60's off the foot brake.
Hemi-its runs CalTrac's and mono leaf on his '63. might want to PM him, see what he thinks...
68 Hemi what does your car run in the 1/4 and what mph? I 60 ft 1.50 to 1.53 and run low 10.50's at 128-129,looking to improve 60 to at least low 1.40's
I ran them on my old 68 RR, it did lower the car about an 1" IIRC, not sure if they helped much in 60 ft times or not I had installed them @ the same time as the CalTracs, I ran the original HD leafs for a couple seasons before I switched to the lighter Calvert mono-leafs, that did help a few hundredths, the sliders do free up you springs to travel in an arch & work under a load, so I think they would help to improve your 60 ft times, but IMHFO it's not going to improve the 60 ft times 2 tenths, maybe a couple of hundredths, over a none slider equipped Calvert CalTracs set up
I don't think it would improve 2 tenths either,I am pretty sure it won't,but .05 to .1 would be good,gotta find something why this car won't 60 LOL
EDDIE B
depending on weather any where from low 10:30's to low 10:40's @ 130 i think my dart works pretty good considering its very nose heavy. figure iron mega block, iron hemi heads, alum cross ram with two carbs, and a big cooling system. she's probably not biased real well. but its pretty consistent long as the track is prepped well.
