Trim Help
Finallygotmine
7:03 AM
Venice Fla./Eagle River Wi.
Need help with some trim that I don't see on many Roadrunners. My car came with the two pieces of trim in the picture. Notice that they are not exactly the same. One has a bigger notch than the other. I need another piece with the smaller notch.
This piece of trim underlines the rear quarter window on a 2 door post car. If there is a thread that discusses this unique piece of trim, someone please post a link to it, or if you by any chance have one, please PM me. Not even sure where to look because I see so few on cars.
Thanks for any and all help available.
Not sure. Could they be door sill extensions? Running to the rear from the sills. Just a guess. Good luck.
May be too long for those. They kind curl up like the piece above the quarter windows exterior.
That trim is refered to as "belt moldings", the pieces in your pic are indeed the pieces under the rear quarter side windows....oftentimes(but not always) found on cars with vinyl tops. There should be pieces that run along the exterior side of the door glass as well.
Yes, these actually are the exterior pieces. Sorry, I should have made that clear. Does anyone know if these are reproduced or somewhere I can search for them? I have a guy that can make them exactly the same with some welding but it is going to cost about as much as 10 pieces of trim. It would just be easier to find the correct one.
BTW, it's a 69 RR
As far as I know, no one is reproducing the belt moldings for the 68-70 B-body cars. Used from a donor vehicle is probably your best option at this time.
