correct service port for useing cans of r-12
69rrnut
11:43 AM
ohio
73 dodge charger ,,,,fact. a/c,, 3 service ports on fact. comp.,,,,,wich one for connecting cans for service,,,low press port,,,,, drivers side top of unit,,,,pass side top of unit,,, or drivereside hose fitting going into drivers side back of comp, THANKS
You want to charge the AC system on the Suction side of the compressor. (Low pressure port)
Also best if the system is running !
Be careful my friend....Never attempt to service a/c on the discharge side of a compressor. Is a very good way to hurt yourself, or worse. If you are feeling uncertain at all, maybe get some help. It is a simple task to service the system, but can go very wrong if you do not use the correct ports.
The line from compressor that goes to the receiver/dryer (where sight glass is typically located), is the discharge, or high side, of the system. So the other line at compressor is the suction, or low side, of the system. Many a/c compressors are actually marked at the fittings on back of compressor, but then again, many are not marked. One other clue is suction side lines are larger than discharge.
Also, did you find how you lost all of your refrigerant? If it is indeed all gone, which I assume it is, then you really should evacuate the system before recharging. That will also show you that you still have a leak (if system is unable to hold a vacuum). And add compressor oil to system when servicing too. Everyone seems to forget that part. If the R12 leaked out, so did a lot of the oil. It sucks to have a fully charged system only to have compressor come apart from lack of lubrication.
Good luck!
Good luck!
All ture here But on a R-12 system I beleve bot ports are the same size .
R-134 uses a large and small port.
I could be wrong as it's been some time since I have done an R-12 system !
You are correct about the port sizes. That feature was added to systems to make them idiot proof when servicing. But I was not talking about port sizes. I was talking about the actual tubing/hose diameter at the compressor. Suction side is larger on any system, automotive to rooftop a/c. Was just trying to give him one more way to be sure he was not going to hook his can of freon up to the high side of an operating a/c system.
Got ya ! Honestly I don't know why you would want to keep the R-12 as it is so expensive ?
And for the price of a flush and retro kit its a better deal to go over to 134. Probly has a leak anyway and need the system cleaned and vac'd down. So this would be the time to do the swap over. I know that 12 is said to cool better but I have gotten some great results with 134 ! All that is posted is good info but its up to the owner in the long run.
You are right. Is a very good time to do the conversion. R134 does a good job. It is more prone to leaking than R12, but if correct hoses are used it is a non-issue. Funny thing is R12 isn't that expensive anymore(it was the taxes that made it stupid, then the demand, but demand is almost totally gone). At least compared to prices in the 90's. I still have 60 0r 70 lbs of the stuff. Should've sold it 15 years ago. Probably would have made enough to buy another Mopar.
be careful my friend....never attempt to service a/c on the discharge side of a compressor. Is a very good way to hurt yourself, or worse. If you are feeling uncertain at all, maybe get some help. It is a simple task to service the system, but can go very wrong if you do not use the correct ports.
Also, did you find how you lost all of your refrigerant? If it is indeed all gone, which i assume it is, then you really should evacuate the system before recharging. That will also show you that you still have a leak (if system is unable to hold a vacuum). And add compressor oil to system when servicing too. Everyone seems to forget that part. If the r12 leaked out, so did a lot of the oil. It sucks to have a fully charged system only to have compressor come apart from lack of lubrication.
Good luck!
thank you plumcrazybee!!!!!!! R12 is very cheep, midwest swap meets thru the year 10 to 20 per can ,,,very plentiful if you look and shop the swaps,,,,,hit the jack pot at norwalk monster mopar last year case of 12 for 120 ,,,,,worst leak ever had on any car gm or mopar is needed one can per season,,,,also r-12 molecule,, spelling bad ,,is larger than 134,,, so any leak is worse if not corrected switch to 134,12 is also colder,,,that being said if r12 now then r 12 forever ,,,also have passed up buying full 25 pound cans of 12 ,,,,because cans so easy to find and use ,,systems with sight glass are great for do it yourselfers,,,,,,thanks for everyones input ,,,,lots of natural ac arround here below zero all the time ,,,,,gime some of that global warming!!!!!!
Best on the low pressure side with can upright so freon is going into system as a gas, not a liquid. ALSO, after opening valve on r12 can, put in a bucket of hot water to get freon to leave can easier. A/C running also works better because the low pressure side should be in the 35-45 degree range and a hot can of freon - the gas will jump into the system making your life easier.
NEVER put it in as a liquid as it can hit the compressor and break a piston.
short stack
The port at the back of the unit is the correct port. not the one on the cylinder head or muffler.
Needless to say, you should have a gage set, and factory service manual before you start, but if not, at least have it vacuumed down before filling the system with gas, as not vacuuming it can cause very high pressures with decrease in cooling, or even a burst hose under hard usage.
