- 4:58 PM
- Apr 13, 2012
- Granite Bay CA
I really need to improve the brakes in this car!
I'm running the Cordoba 12" front rotors with single piston 2.75" sliding calipers. The rear is the Dr Diff disc kit with 10.7" Toyota based rotors, 1.5" single piston Mustang based calipers. I have a 75 Dart power booster with a 15/16" master cylinder. The engine makes low idle vacuum so I added a vacuum storage tank, but it still isn't enough. High speed braking is great but at lower speeds, the brakes just are not nearly good enough. I have looked at using an electric vacuum pump but the new kits are often $260 and up.
In 2012 I tried switching to a non power (manual) master cylinder. I tried 4 different ones, all with different bore sizes ranging from 15/16" to 1 1/8". None of them worked well either. Each one was capable of developing a firm pedal but none of them gave adequate braking. In fact, the braking was so bad, I was barely able to get the tires to skid on gravel! I really like the light weight and simplicity of a manual brake system and would prefer to go that route but with the luck I had, I really would benefit from seeing what other setups that other guys have used.
