frank
I have a problem that maybe someone can help me with.
The 69RR 4speed will not start unless I put the car in gear push it back and forth then it will start. Also if I try to start it in gear it will jolt forward then start. Someone said that maybe the starter and celinord teeth are sitting on top of each other and moving the car in gear resets them into place.
When I try to start it all it does is click then I have go through the process I just mentioned.
