vetteman91
I just had a similar situation. MY 383 had not run since '98. Replaced point dist with EI, had power to pos side of coil but could not get any spark. After fighting for some time I found out the tach inside car is shorted out and was killing the impulse from neg side of coil. Removed tach wire from coil (-) and it regained spark. Got it to start with dist loose and dialed it around until it idled on its own.  I just started back at basics and hooked up only what was needed and figured it out on accident.
