superbee_68
I wanted to share my experience of learning the hard way so that others won't make my mistake. We have all done it, reach through the window to start the car while working on something under the hood. Let me tell you, never reach through the steering wheel to grab the key. I am buttoning up the restoration on my Belvedere and had just put on the power steering belt. I usually break in a motor with the power steering belt off, one less fluid to worry about. I reach in the window with the car on the lift with the front wheels off the ground. I planned to start the motor, then adjust the self center on the steering box. I reached through the open window and through the steering wheel to turn the key. As soon as the car fired, the steering wheel started turning to the left and locked my arm between the wheel spoke and the steering column. I was alone with no cell phone and thought my arm was going to break any second. I managed to twist my arm to the left and the steering wheel took off again pinning me against the column shifter. The key was still out of reach for both hands. I was pinned for about 30 seconds when out of sheer luck, the car sputtered and died freeing me. The car runs great and had no reason to die and has not died since so I have no idea what saved me.
After investigation, the rod that centers the spool valve had been removed by the previous owner. The valve slammed all the way to left turn and got stuck so there was no going back to the right. I have three huge bruises on my arm and it looks like a zig zag shape. The x-rays show no broken bones. Luckily I'm a big guy. A smaller boned person would probably not have been so lucky.
Never reach through the steering wheel to start a car. Get in the car and sit behind the wheel with your foot on the brake. You never know what's going to happen.
