CoronetDarter
I'm in the process of pulling the 440 out of my Coronet. I've pulled engines in the past and have always been able to remove the flex plate bolts with a 3/4" box wrench. It wasn't easy but it worked. This car is not cooperating - 3 of the 4 came loose but the 4th is being stubborn. I've used 50/50 trans fluid/acetone, WD-40, still can't break it loose.
I've heard of people removing engines with the t/c still attached. The FSM warns that the t/c must be removed with the tranny otherwise front pump damage can occur.
Has anybody pulled an engine with the t/c still attached? My alternatives are to pull the eng/tranny together or drop the oil pan so I can get a socket on the bolt.
![success[1].jpg success[1].jpg](https://www.forbbodiesonly.com/moparforum/data/attachments/135/135001-d7fc20c205a611d88f05eb9baf6c4e45.jpg?hash=1_wgwgWmEd)
