Air grabber air cleaner ***.
69 GTX
6:14 PM
Milo, Iowa
Air grabber air cleaner base.
Is there any differance between the 440 & the 383 airgrabber air cleaners (the base?), how can I tell? thanks
I gotta say.......The title of this thread is pretty funny. "Air grabber air cleaner ***."
I believe there is a difference..possibly a drop in the base? Someone should pipe in.
Yes, the 383 base has a taller neck than the 440 base. This is to maintain the same overall air cleaner height due to different deck heights of the 383 and 440. Not sure about the *** though.
I do believe the 440 *** has to maintain a little more roundness than the 383 ***. Haha
Yes there is a height difference to make up for lo deck and hi deck.
Place base on a flat surface, if the carb opening isn't pushing the whole assembly up off the flat surface you have a 440 base.
Place base on a flat surface if the carb opening is touching the flat surface first and holding the rest of the assembly up you have a 383 base.
Ron
Glad I could brighten everyones day with my fat finger typing! I should proof read more. *** you were gentlemen :bootyshake:
Oh and thanks for the info!
Your not the first person to *** this question. Lol. I have a low deck block with a 440 base. 69 RR. With a 1" spacer it wont allow the hood to close, but without the spacer is closes fine. With anything other than stock intake and filter base, tou have to play with manifold/carb spacer/filter base combinations to get the height right. It can be a real pain in the ***. He he.
Gentlemen ..., gentlemen, the A12 cars were made to "Haul ***", not clean it. While there were in fact many "Clocks Cleaned" and "Doors Blown Off" through the years, any "*** Maintenance" (cleaning, kissing, Sucking, ect...) was always, always performed by the Blue Oval and Bowtie boys. :headbang:
It's been bothering my *** as to why I typed that, then it dawned on me. I meant to type assm. I have had a few *** puckers due to WOT below the air cleaner:icon_geek:
