re: 1969 Plymouth GTX rear suspension
uwss
11:17 PM
Dallas, Texas
Question: I have a 4:10 dana60 ; I removed the air shocks and installed Viking shocks. I added air bags attached from the leaf springs to the frame. I have since added an Addco rear sway bar. ( I know Addco isn't the best but the price was very reasonable not to ) When I get on it, I can feel the rear lifting, is this typical ? I was hoping the rear end would be more solid. I, also, have caltracs, too.
air bags have about 70 psi in them
4 speed, 440 stroker 512 700 horses.
sounds like you have alot of counter productive stuff going on. yes with caltracs you should have some separation. what are you trying to do? i sure wouldn't have caltracs on something i want to do corning with (or ride quality). vise versa i wouldn't have all the other stuff if i was going is a straight line.
The air bags are supposed to keep the rear end level so more power is transferred to the ground. The old air shocks were worn out and I decided to go with the Viking shock since they are adjustable and rebuildable. Caltracs are supposed help transfer power to the wheels; eliminating leaf springs bending at the weakest point and help with axle wrap.
i know what caltracs do and how to make them work. this is my car. doesn't need air bags or a rear sway bar. those are best used on chevelles and mustangs.
Good looking car!!!
thanks! so yes you the rear end will rise for the caltracs to work correctly. as you can see my car lifts a pretty good amount in the rear.
this is how it normally sits.
UWSS,
I have to agree with 68 Hemi GTS. Unless you are going after a factory appearing car I would go Cal Tracs. No ifs, ands, or buts. I have been working on the rear suspension of my 66' Sat. My vision for my car is a factory appearing 1966 Plymouth Satellite which will be street driven with an occasional trip to the track. I to have a 440/512 that will make close to 600hp and 650tq.
Rear Suspension: MP XHD leaf springs, MP shackle kit, AR Engineering front hangers and reinforcement plates, ADDCO 7/8" sway bar, Rancho RS9000 shocks (9-way adjustable), MP shim kit, Mancini replacement U-bolts, and Mancini Racing adjustable pinion snubber. View attachment 183009
IMG_0642.jpgrobinsonwr, my setup is pretty much the same including the snubber. However, I added the airbags over the axle to keep the left and right side stable during a power take off. I have rebuild the 4 speed and I am in the process of rebuilding the front end. I am adding a front strut over the shock tower; all new ball joints. I do have one question ; do torsion bars go bad and do I need to replace them ? I am keeping the 11 inch front brakes for now. I am doing the 512 stroker; eagle 4340 crank with 4340 H rods, ATI balancer, haven't decided on rockers, cam, yet. I have a 6 pack setup but I am thinking of going with the single plane intake and a 950 carb.
View attachment 183280robinsonwr, my setup is pretty much the same including the snubber. However, I added the airbags over the axle to keep the left and right side stable during a power take off. I have rebuild the 4 speed and I am in the process of rebuilding the front end. I am adding a front strut over the shock tower; all new ball joints. I do have one question ; do torsion bars go bad and do I need to replace them ? I am keeping the 11 inch front brakes for now. I am doing the 512 stroker; eagle 4340 crank with 4340 H rods, ATI balancer, haven't decided on rockers, cam, yet. I have a 6 pack setup but I am thinking of going with the single plane intake and a 950 carb.
That is absolutely beautiful car. So far these are the components I am using for my 512 build:
Block: 1971 nonhp .060 overbore
Crank: Eagle 4.25 stroke (2.20 rod journals)
Rods: Eagle 7.1 h-beam (.990 pin)
Pistons: SRP
Compression: 10.5-11:1
Balancer: Professional Products 90013
Intake: Indy 4150 dual plane
Water Pump: (Housing)MP Performance Aluminum, (Pump) Milodon Aluminum
Oil Pan: Moroso 7 quart with pick up
Heads: 440 Source Stealth (929-16 springs, 741-16 retainers, 611-16 locks), ported 290cfm @ 600.
Camshaft: Hydraulic Roller, Comp Cam custom grind (ADV Duration 281-287,@ .050 230-236, lift 622I & 625E w/1.6 rockers. GRIND #: CRB3 3194 /3196 HR111.
Rocker Arms: Crane Cams Gold 1.6 (MP rocker hold downs)
lifters: Comp Cam 8921-16
Push Rods: Smith Bros. Custom
Carb: 950 CFM holley
Exhaust: 1968 HP Manifolds or Hooker 2" primary's
Why hydraulic roller vs solid roller on the camshaft ? Do torsion bars go bad ? Thanks for thumbs up on the picture. I am leaning towards a 11:1 compression. I have a 74 block that checked out ok. I am doing 30 over with the 512 stroker.
So whats the best setup for both worlds ? street and track.
UWSS,
I love solid rollers but just wanted to try something different. I am hoping at the end of the day it will be a little more maintenance free than a solid roller. My car is a designated street car with the occasional 1320 in its future. I would suppose torsion bars react much like leaf springs in the fact that age will deteriorate the performance. I will change mine when I do the front suspension. Yes I want the best of both worlds but lean heavier towards streetability and drivability than all out performance.
