Lower Control Arms for a '70 - aftermarket or junkyard?
SlinktRR
12:10 AM
Dallas TX
I need replacement LCA's and can't find any aftermarket, wondering if anyone knows if these are produced anywhere. Also when searching used, which years interchange with the 70 B body? Thanks!
The only aftermarket that I am aware of is a tubular type. If you want the factory style you would need to look for a used set either through here in the wanted/for sale section or at junk yard or ebay. We have parts to rebuild and reinforce them with new pivot shaft,bushing, stiffening plates and torsion bar adjusters if you are interested
James
Actually I just realized you are in NJ. If you are located in Northern NJ. I know if a junkyard near me that has a dozen or so B bodies as I have gotten arms there in the past. PM if you are interest and I will give you the name and number.
James
James
James
Thanks James. Right now I just want to get aligned and go, but eventually I will need to do a front end rebuild. PST is on my list for next winter thanks for your help!
