Installing new Spark plugs
Canadian1968CoronetR/T
6:41 PM
Canada,Peterborough
Ok I just bought a set of plugs for my 1968 coronetR/T, 440 hp.
I thought I was all set I can see them fine I dug out my spark plug socket and ratchet.
That's when every thing came to a stop, my socket will not fit between shock tower and engine, so for the question is do I need a special socket or what's the trick??? Help
Bryan
Some motors you needed to loosen a motor mount and raise the engine slightly to get the plugs out.
I'm guessing #2 plug, for stock heads I think you can get a combination wrench on the plug to get it out, for aftermarket heads with the recessed 5/8" Hex, Snap-On makes a nice short plug socket that will slip over the plug and then you can get a wrench on it.
Thanks I think I have sockets like this, will try tomorrow
Most spark plug sockets have a hex head you can put a wrench on, that's what I do anyways.
X2 You shouldn't have to buy a socket.... use never seize on the threads of the plugs and dielectric grease on everything else
Get help. Every gd task is critical. Hope you got NGK's. Anti seize, torque, gap etc.
I like to set the gap (.035) and prep up everything then change them out one by one and ngk platinum are the best....
You need one of these - offset box wrench. Works every time.
I have have set the car up on jack stands and removed them from underneath PIA but at least you can see what you are doing.
Besides of another brand ill do it the same way
I used a 3/8ths drive socket on my 440 Challenger.....but I think I still used an open end to turn it. Dang...30 years passed by in hurry!
I have the 440 Source heads on my 440, and the #2 plug is so close to the shock tower than I could not get a normal spark plug socket on it, and the spark plug hex is recessed in the head so you can't get a wrench on it. That is why I mentioned the socket above.
