- 8:19 PM
- Nov 20, 2013
- Ft Lauderdale fla.
This is the nut shell on the last question... if the car originally had power brakes a manual system will need many parts to go to manual including a pedal,brackets to hang the pedal, linkages a backing plate..... manual to power and back to manual is a big difference between all the combos.... if you suspect it wasn't done right to begin with... you are in for some serious fabrication... you may get lucky.... look under the dash and see if it has a multiplier set up where one rod from the pedal attaches to an arm that pushes another rod that goes into the back of the booster... that's the power set up.... manual has one rod. Also has a different plate between the booster and fire wall it attaches to..... on my car I have a power drum car... going to a SSBC KIT power system made for converting manual to power I had to drill and make my own rod with a combo of parts.... the easiest way is to verify if it was originally a power car or if you have a manual car and start from their... depending on which pedal to firewall.assembly you have will determine how easy it will be to go to manual.... or like above to a replacement pirate Jack booster.... either way you're master cylinder is junk but not all masters fit depending on all the for mentioned possibilities.... someone could have really botched it up under there it done it right take some pictures and post it and I will look for the thread and help point you where you need to go before you buy anything know what you have... I pulled my steering column and front seat to start with so I could see and operate once I new what mess I had under there...
