2059
- 9:36 PM
- May 4, 2012
- North Central Indiana
230I 236E
Haven't mapped the curve.
At idle, none on the ported side.
Didn't check manifold vacuum.
What are you thinking as far as initial to try?
I'll go back out and hook up the test equip't and check.
It will run cooler with some more timing at idle. What's the cam duration at .050 lift? Have you mapped the entire ignition curve? How much vacuum is it pulling and how much timing is the vac advance adding?
