65 coronet front brake shoes cracked
fwi
8:28 PM
BHC Arizona
Still have a lot of shoe left but they are cracked...should I replace these?
it looks like they were overheated. personally, I would replace them along with freshly turned drums.
They are toast.... I would check the drums and weel bearings for wear and excessive heat blueing cracking etc....
Looking for an excuse to save $20.... you won't find it here.... do both sides of the car at the same time....
Are you serious? :icon_rolleyes:
Actually I was planning on doing all 4 corners.....!
and check the rears while you're at it.
Exactly... bearings, seals, hardware kit to include '69 and up adjusters, weel cylinders,and all 3 rubber lines then shoes and drums.... and check out the thread on ventilated drums I started on here.
:head_smack:
No, did you actually think I was trying to save $20????:jerk:
There are people that will try adn save the 20 bucks if they can.
Personally I believe brakes are #1 with a suspension in good shape as #2 and good headlights as a close #3 in importance.
