turn signal flasher
pjm8047
1:07 AM
Clay,NY
Turn signal flasher only flashes on right side and stays sold on drivers side.bad flasher?
Ive replaced the switch 2 years ago.it works sometimes but slow
Headlight switch might cause that. Are they bright? Did you try another flasher? What year?
There's a ground on the body front and rear of the car one on each side but they connect together at one point.... on the front it's by the radiator drivers side on the rear it's on the valance... follow the wires and see where they go sometimes the wire looks good but is blackened with corrosion and has lost it conductivity...
The ground up front is real easy to reach from the radiator... it's on up high by the top and if it got a little tug it could have been compromised...
i wish someone had a pic.that would make left side run slow?
I've seen the ground wire on the radiator bolt before. You might be onto sumting.
I was thinking the lights would be dim with a bad ground but it might be just enough to keep them from flashing...
Are the grounds colored brown on that year?
No .... from the harness from the light buckets...
Someone post some pics....
At some point the free consultation stops and I start charging buy the hour...
Well, hell, try the new flasher.
Think simple things first...
simple... if broken, won't flash the right side. Is just one flashers for both sides ;) works or not to both sides
if one side doesn't flash you don't have load able to heat the bimetallic inside i.e. no high watt bulbs. Are you just looking at cluster light keeping on, or all bulbs outside on left side keep lighting up without blink?
both drivers front and rear bulbs wont flash.they do sometimes
