Anyone have the shift shaft & throttle shaft seal part #s for a 727?
4xfourfun
8:21 PM
Godfrey IL
Started out thinking I just needed a pan gasket on my 69 RR. Well, it appears I have a couple small leaks that combined make it appear to look like a larger leak. I'm dropping the valve body now, but does anyone have good part #s for the shift shaft & the throttle shaft seals? Initial calls to the two local parts stores have come up empty as usual, and I find if I give them the part # half the time they have it in stock! I did some searching and found some conflicting info so just thought I would ask the experts. Thanks in advance.
shift shaft seal, 4505098 chrysler, throttle lever size have no no. but I have ton's of them if you need one, any body that does' trans work should have one around.
Thanks for the #, if I have no luck with the other seal I'll let you know. Anyone know right off what the torque spec is for the ten valve body bolts? They seemed tighter then I expected.
