torque specs of Crower lifters
am3rican
5:06 AM
Willow Grove, PA
I have aftermarket Crower lifters in my 440. Right bank is making a slight ticking sound. I have purchased valve cover gaskets and will be adjusting the lifters. Anyone know what the torque specs are for lifters
I believe you mean adjusting the valves. First, most Mopars are hydraulic, and do not require adjusting. But, if you have installed adjustable rocker arms, you adjust them to a certain gap on solid lift cams, not torque. If you are running a hydraulic cam with adjustable rockers, you adjust to zero lash, and then another 1/2 to 3/4 turn.
Thanks 69bee. I did mean the rockers. I have zero experience adjusting valve lash in a MOPAR or any car really . Can you recommend any tutorials? How do I measure the lash
Am3rican You need the cam specs for lash. a feeler gauge, Box Wrench, and rachet. Also a good Remote starter button. You should Adjust Cold and reset hot. 1/4 turn past end of ticking is good. Make sure lifters are well lubed if the lifters are new. A spare old valve cover with top cut off will allow you to adjust hot and listen for sound.
First, is the cam a solid lifter cam, or is it a hydraulic lifter cam?
Do you have factory rocker arms? Or aftermarket adjustable?
It's been 10 yrs since the build. I have no idea but I am going to assume stock? Here is the build sheet from PO.
Sealed Power E424K Rings
Sealed Power Camshaft Bearings 1453M
Sealed Power 4924M Crankshaft Main bearing
Speed Pro Forged alum Pistons L2266F
SA Gear Double Roller 250 78104
CROWER Stage 3 32918 HYDRAULIC FLAT TAPPET CAMSHAFT - .444 Int (1.5R), .467 Ex (1.5R) Lift,
Crower 66032 hydraulic lifters
ARP Rod Bolts
Sealed Power V1386 Valves
Crower Single Vale 68302 Springs
Well, if you have the factory rockers there is no adjustment. If there is a noise it may need to be run to pump up, if that doesn't do it more diagnosis will be required
