1968 Plymouth GTX Convertable
Mattfi1
10:59 AM
Cheektowaga, NY
Hi, I am in the process of looking for color matches for my GTX. I know the exterior car color but need more info on the interior colors. There are two interior colors, the dash is a darker blue and the door panels are a lighter blue. Goes anyone know where I go to look up paint codes for this car. I'll attach a few pictures.
This is what I got
CAR: Plymouth GTX 2 Door Convertible
ENGINE: 440cid 4-bbl HP V8
TRANSMISSION: 4-Speed Manual Floor Shift
TIRES: F70x14 Red Side Wall, Steel Belted
BUILD DATE: May 09.
AXLE: 3.54/3.55 Rear Axle Ratio (Dana60 or 8 3/4), Sure Grip
INTERIOR: Sport Trim Grade, Vinyl Bucket Seats. Light Blue Interior.
PAINT: Monotone Bright Blue Metallic Paint.
OTHER: Light Blue Metallic Upper Door Frame Color. White Horizontal Sport Stripe.
MOLDINGS:
19: Wide Sill Mouldings
30: Body Belt Mouldings
518: Unknown Option
OK that probably didn't help. I've only had one blue interior car which was a 70 RR so I'll let someone else help.
Nice car
Dash paint
Oh Yeah Baby! I've got one of those! '68 GTX Electric Blue. Here's your Dash color:P8240311.jpg
O.K., you'll see the 2nd line from the bottom all the way to the right, UBS.The "U" is for the upper interrior door color.
The "B" is for buffed paint. And the "S" is for the is for the stripe or accent color. Frost Blue Code "U".
Ditzler PPG 13445. Good Luck!
Thank you, should be starting on paint in the fall. The car is at AMD's Installation Center for the metal work. There are a few more pictures in my Gallery. Mattfi1
