GearAddict
just in case you didn't know, reverse isn't synchronized, so some gear grinding is expected if you put it in too quickly
water leak may be the wiper pivot seals dried up
wiper motor may need the ground cleaned
Thanks Dave... I tried looking at the pivot seals after dumping a bucket of water on them and while dried up, I didn't see anything coming through. I may have to test them with a full shower from the hose.
No Synchro's on reverse is a good point, but I'm pretty sure it grinds no matter how fast or slow I try to put it in gear.
Wiper motor ground is new, but I'll go back and check it.
Hey Scott,
Nice to hear you got your fuel leak addressed. I will again (briefly) get on my soap box: If you don't have a fire extinguisher in the car, GO OUT AND BUY ONE NOW!!! It is cheap insurance... :icon_thumright:
OK, off the box: First, with your transmission woes: Trust me, I feel your pain, and mine isn't even drivable yet. The worst part is, mine WAS OK and I screwed it up because of a dumb mistake (I should have known better...). There are some nice kits out there. If you intend to drive your car a lot on the highway, maybe look into an overdrive. Passon Performance has a kit that lets you rebuild your trans into a "Hemi" 18 spline overdrive unit. Might be where I go with my transmission soon.
As far as some of the other problems: I agree with Basket Case, in many cases things might be simple fixes. It seems to be human nature to immediately assume the complex fixes, and very often the fixes are simple. It always makes sense to start looking at the simple things to rule them out. Especially with electrical gremlins, grounds are almost always one of the first things to check. I can't tell you how many times I have kicked myself after finding the simple problem after hours of chasing complex stuff...
Hang in there and work out the issues to get the car "sorted" as Ed from Wheeler Dealers would say. You are in the home stretch!
Hawk
I hear ya on the fire extiguisher. I keep 2 in the garage, but probably not a bad idea to have one in the vehicle as well.
I have been looking longingly at the Passon kit for the past 2 days... Anyone know hard hard/easy it is to do? I've never tinkered in a manual trans before.
"Get it sorted" is exactly the mode I'm in..thanks for the encoragement.
Scott, old cars are a test mate, and so far you keep passing!!
Can't wait to hear the results of your new exhaust...
Thanks Frank, It doesn't feel that way sometimes, but much like my guitar playing, "I'm not talented....I'm just persistant."
Just got a call from the exhaust shop...after several delays they say it's done. On my way to pick it up in a few hours.
