Fastest pass Ever with the Black Dodge
LOL .:D
I have not been on here much this last year.
Always a fun time at the track. with NENDRA racers..:D
but.......you replied to BOBTILE before mine. What's up with that? I thought I was your boy?
Im at 32 degrees timing now with 15.8 compression.
I want to try 34 degrees to see if I gain anymore for the big race this Saturday.
Am I pushing it with 15.8 compression?
You might spin off the line putting to much too fast JMHO
Not as long as there is no detonation. I doubt a small chamber will see much improvement at 34 degrees. But it mike like 30, never know until you try.
:eusa_think:
I'll bet it would MPH like a BEOTCH.
i'm out of time because the small tire 10.5 race I this Saturday. 3 time shots is a possibility and then it's "LET IT FLY".
:eusa_think:
It just went 157 mph on Saturday.
sounds like about an 157mph you say
guessing 3100#'s give or take a 100#'s with car & driver
1/4 mile with appr. 960-980hp @ sea level to be able to run 8.60-ish ET
is what it calc's out as...
should rock & roll for sure
good luck
good luck
No it's 3389 lbs. with car and driver.
Car likes 34 degrees but I lose 1.5 mph. Et goes down though.
This motor better make more than 960-980 hp or i'd be looking for a new hobby. Hell my 13:0 584 hemi in my 5 plymouth made close to that.
Chris,
I'm sure you making over 1000hp at the crank but You're probably putting 960-980 to the ground.
yeah 157mph at 3389#'s, it's calc's out at like 1050.28-hp @ sea level
I thought your car was 2900#'s & guessed at the weight with you in it for the 3100#'s
Not trying to offend & it's not exact science, allot of other factor not in that figure either,
it's just for my general reference purposes...
Drag racing is all about the #'s
http://www.wallaceracing.com/et-hp-mph.php
Budnick's I wish it was 2900 lbs. I got to figure a way to shed some pounds without ruining its look and originality. It's too nice to cut up.
yeah she's a perty girl, I wouldn't want to cut on her either
So the cutting has begun to install the new hood scoop. Mocking it up and then off to my body man for final paint and fit. New hood pin location has to be fitted AS well.
The black Coronet is now called Terrible Terry!!!:grin:
Who spackled your garage walls?
Just got these new Book Racing Carbs to put on and see if they make more power than the SV1's from Prosystem.
sure are perty
I hope all works well, good luck
Was going to go testing today down to Cecil County but we got 6" of snow again last night.
