GearAddict
Ok, so I have a couple of options in front of me that I'm considering, just to get me through for a year or so, while I work on buying parts/building the final engine combo I want for my 69 RR. I'm not racing the car at all other than a few stoplights. Really hoping to build something that is low-buck, somewhat dependable and has reasonable power (350-400HP) range
Here's what I have to work with.
Car is 69 RR with 4 speed and 4.10 gears
1. 383 currently in car running, 516 heads, unknown pistons, currently reading low comp (95 - 110ish range). Eddy RPM manifold, MSD ign, headers, 509 Purple Cam (long block and cam built by previous owner). Doesn't burn oil significantly, is a bit of a dog down low, but screams up top in the 3K-6K range. I have had a horrible time dialing it in and I believe alot has to do with the heads needing work and too much cam.
2. Fresh rebuilt set of 906 heads with hardened seats.. good for up to .500 lift in current config.
3. A buddy of mine has a complete 400 shortblock assy that is taking up room and I can get for an 18 pack of beer. He got it in trade and never ran it. Stock bore, cylinder walls look great (no ridges), clean looking flat top pistons, stock 400 crank, spins free. Unknown cam.
4. Here's the rub... $600 to spend on all other items.
The 2 options I'm considering are
A. Assume the 383 bottom end is ok, pull 516 heads, hope (pray) to get 8.5:1 or better comp ratio with 906 and steel gasket. Replace 509 cam with better grind for good power idle - 4K range based on CR. total cost $400?
B. Dissasemble 400, hone and re-ring, new bearings, cam as above in option 1. 9.25:1 CR (flat tops with .020" gasket and .026" in hole). 906 heads and all accesories from the 383. $600?
Am I crazy to think that a simple ball hone and re-ring will be ok?
