FOR SALE Original 426 Hemi heads dated 1968. Original intake. Rocker assemblies.
jercars
12:32 PM
Carroll, IA
Feedback: 2 / 0 / 0
426 Hemi heads with September and December 1968 casting dates complete. Chrome valve covers. Original intake with top modified. Rocker assemblies with aluminum stands, the rest appears to be original equipment. $2000 for heads, intake, and valve covers. $1500 for rockers. Located western Iowa.
There's a 65 426 Wedge motor on here. Will these heads run on that motor?
Hmmm. Your straight up 71hwy???
not without some serious work on the head bolt attachment, you have to weld tubes in the block valley area for each inner head bolt
best to get a stage 5 if you need a hemi head on a wedge block
If that's a max wedge do not touch it
if a passenger car 426 then still relatively rare
wyrmrider is right. The top row of head bolts don't match up, then you will have to make such big notches on the top edge of the deck for push rod clearance that you are almost guaranteed to get into the water jackets, after that you will have to drill and tap external oil return lines into the back of the heads and run them down to the bottom of the block since that block won't have the necessary oil return passages for hemi heads. On top of all that don't screw up a wedge block. If you go hemi just buy an actual hemi block so it's all correct and be done with it. And yes I am right on Hwy 71. :)
Let's keep comments to the items for sale. If you have any further tech question please post it in the tech area.
