SlinktRR
I'm in the planning stages for a new build. Right now I have two motors. The 71 383hp is complete, in the car and is mostly stock other than the MP cam that's in it. I bought this used a few years back and it runs great, solid street engine. I took the stroked 440 short block (no heads, needed rebuild) that was in the car out and replaced it with the running 383, idea being to build the 440 at some point. 2015 is that time.
1969 440 bored 0.050" over
4.25" stroke crankshaft
MP P4529427 flat tops (400 0.030 over pistons)
3000 stall converter
manual brakes
1 7/8 Hooker headers, 2.5" pipes
I want to use either a solid or hydraulic flat tappet to keep things manageable on cost. Heads will be either 915 iron or the trick flow 240 78cc's which are coming out soon. I have been looking at the holley street dominator intake so I can keep hood clearance with the 70 air grabber, carb is open at this point.
This is my short list of cams:
1) Voodoo 60304 276/284 .513/.531 110 LSA
2) Comp XE285HL 285/297 .545/.545 110 LSA
3) MP528 284/284 .528/.528 112 LSA
Would like to see what other cams are out there. Not planning to track the car but would definitely like more torque than I have now. How much lift can I afford with the pistons I have? Wouldn't be averse to buying new pistons either, but trying to use what I have if possible. Looking for 10+ inches vacuum and mid range power.
manual brakes
