ozmercury
Hi there,I have a 72 roadrunner have had it for 2 years bought it form salt lake city Utah,had it shipped to Brisbane Australia.i also have a 1968 mercury cougar has 331 and 4 speed AOD transmission.I am building a 493 stroker RB and was looking at the 727 with gear vendors overdrive unit,the cost of the 727 with steel drum and GV OD was quite a lot,so I researched cutting the bell housing off and bolting a JW BB Mopar to powerglide Bellhousing redrilledon cnc to fit the AOD FB transmissions in NY supplied this to me.most mopar people will not know much about the AOD it was 1980-1992 mustang trans the OD is .67 so with 3.7 gears engine 1900 rpm t0 do 100kph(65mph)stock AOD can only handle about 300hp with direct drive lock up ,but the AOD can be retrofitted with the geartrain from a late model 4R70W with Constant pressure manual Valve body and extra clutch plates in forward and direct drums can be built to handle 700hp 650ftlb.the overdrive is just a cruising gear no full throttle shifts from 3-4 as the OD band will burn out.Bell housing with modified trans pump $895,1000ftlb 9.5 converter $995,300m input shaft and steel drum $650,flexplate and adapter $340 expensive but cheaper than 727 GV OD .here are the pics so far of the conversion.Gerard Brisbane Australia
