Blownmopar71
I run a 4.30 gear and 28 in tall tire ,on the street its 50 to 55 mph @3000rpm,s. Runs down the 1/4 11.40s going through the traps @ 6100rpm,s
Your speed is in line with your et, to go 11.20's you will need to pull at least 117 mph. A set of ported edelbrock heads would get you where you need to be, also you dont need 110 race fuel in a 10.1 motor. I mix 112 50/50 with 97 Pump, gives me around 105 octane with nearly 13.1 comp.Ok...I need help guys. I bought this car 6 months ago. I have had it to the track twice before winter set in.
Best ET is 11.876 and 112.75. 1.699 60 foot and 7.521 at 660 foot. I think from My combo that it should run at least in the 11:20's or 11:30's. ???
It leaves straight as a arrow, no excessive wheel spin. Best ET is shifting 1-2 at 6200 and 2-3 at 6400.Goes thru traps at 6000. Doesn't lay down anywhere. Engine build is maybe 2 years old and could have 200 runs on the build..the only thing I am thinking is that maybe the rings and/or valve seats are worn and.or valve springs weak..GOTTA BE SOMETHING....
WHAT DO YOU GUYS THINK...SHOULD THIS COMBO BE FASTER THAN 11.876.
440 CUBIC INCH, 3700 LBS
Here is the combo:
1) Probably 3700 lbs although it does have fiberglass front fenders, hood and both bumpers and no back seat with Recaro type bucket sets. 6 point cage.
2) 4.10 Detroit Locker with Super Stock Springs and Pinion snubber adj at the way up.
3) 12 gal fuel cell with big Mallory Pump and big Fram Filter. Filter is new.
4) 30x13.50 MT ET Drag Radials with 11.25 tread
5) Weld 15x10 Super Lites and 15x3's on front.
6) Reverse Griner Valve body with 4000 Converter (Ultimate Converters)
7) Hurst Quarter Stick Pistol Grip with Line Lock
Motor:
1) Holley 950 HP Race Carb with 50cc primary pump installed and 35 tube type squirters and 1" Moroso spacer, No air cleaner on at track. Fuel Pressure regulator at 5psi.
2) Mopar M-1 Single Plane Intake.
3) Hooker Super Competition Headers with no tail pipe exhaust system on at track
4) Iron Heads off 1973 MotorHome. Ported. 2.19 Intake and 1.88 Exhaust Valves. Flow Intake 267CFM and Exhaust 216CFM at .600. Crane Aluminum Gold Roller Tip Rocker Arms 1.5 Ratio.
5) Cam is custom ground (no name) .570 Intake and .569 Exhaust, 104.1 Intake C/L, 108.1 Lobe Separation, 265 Intake and Exhaust Duration Solid Lifter with Smith Bros Pushrods.
6) Reported to me that pistons are 10-1 and that is all I know because I have not had heads off.
7) 440 stock bore and Stroke.
8) MSD Billet Dist with 6AL box with 2 step limiter box attached.
TUNING:
Ignition Timing 37 Degrees Total. 19 Degrees in Distributor and 18 degrees intitial advance. Springs set to come in total timing of 37 degrees at 3000 RPM.
Carb 78 primary jets, 79 Secondary Jets. 35 Tube Type Squirters.
Valve Lash is at .023 Hot.
I RUN VP 110 LEADED RACE GAS.
I set the low end launch rev limiter at 2500RPM, put my foot on the footbrake and floor it and release the footbrake when it is time to launch. The low end rev limiter switch is on the footbrake.
Like I said. I shift at 6200 on 1-2 and 6300 on 2-3 for the best ET's and it goes thru the lights at 6000.
Best time is 11.876 but most of the other runs are 11.92 to 11.95. I have only made 15 passes in the car. Fasted 11.876 and slowest in 11.95......very consistant but I think it should be faster.
PLEASE WEIGH IN AND GIVE ME YOUR OPINIONS
I run a 456 gear and run through the traps at 122 mph goodyear slicks 14x30
I was also thinking that may be the case. Why may I ask and your suggestions always welcome
