FOR SALE LARGEHOLEDakotaDriver/360 Magnum Exh Manifolds
treblig
South Texas
From Corpus Christi Texas, I sell modified large hole Dakota driver and large hole 360 magnum passenger manifolds for B and C bodies. I take these manifolds and machine the exit hole to just over 2 1/4" for the maximum flow you can get for your small block engine using a cast iron manifold. Check out the pics. The manifold sets sell for ONLY $210 plus shipping. The manifolds are sand blasted, checked for damage, primed with high heat primer, top coated with high heat paint then baked for 12 hours at 150 degrees to get the longest life out of the paint job.
I also sell the stub down pipe with the proper "bell" flare along with the adapter flange so you can bolt up your pipes to the manifolds. The flared stub pipe w/adapter flange sell for $30 per side.
I'm the only person selling these "machined" manifolds and I run out of stock pretty often because of the high demand!!
PS - The only other factory cast iron manifolds that have a 2 1/4" exit hole are the very expensive 340 manifolds!!!
Treblig
DSC03513.JPGDSC03504.JPGDSC04084.JPGDSC04005.JPGFrom Corpus Christi Texas, I sell modified large hole Dakota driver and large hole 360 magnum passenger manifolds for B and C bodies. I take these manifolds and machine the exit hole to just over 2 1/4" for the maximum flow you can get for your small block engine using a cast iron manifold. Check out the pics. The manifold sets sell for ONLY $210 plus shipping. The manifolds are sand blasted, checked for damage, primed with high heat primer, top coated with high heat paint then baked for 12 hours at 150 degrees to get the longest life out of the paint job.
I also sell the stub down pipe with the proper "bell" flare along with the adapter flange so you can bolt up your pipes to the manifoldsDSC03944.JPGDSC03942.JPGDSC03981.JPG. The flared stub pipe w/adapter flange sell for $30 per side.
Treblig
340/360/Dakota Manifolds
Treblig
View attachment 230870View attachment 230871View attachment 230872View attachment 230869From Corpus Christi Texas, I sell modified large hole Dakota driver and large hole 360 magnum passenger manifolds for B and C bodies. I take these manifolds and machine the exit hole to just over 2 1/4" for the maximum flow you can get for your small block engine using a cast iron manifold. Check out the pics. The manifold sets sell for ONLY $210 plus shipping. The manifolds are sand blasted, checked for damage, primed with high heat primer, top coated with high heat paint then baked for 12 hours at 150 degrees to get the longest life out of the paint job.
I also sell the stub down pipe with the proper "bell" flare along with the adapter flange so you can bolt up your pipes to the manifoldsView attachment 230866View attachment 230867View attachment 230868. The flared stub pipe w/adapter flange sell for $30 per side.
Treblig
I still have one 340/360 magnum manifold set. I also have Dakota and late 60s 340 driver manifolds. The 360 magnum and Dakota manifolds have been machined for maximum flow!!!
treblig
Still have a few sets in stock
treblig
I have a few set of 340/360 mag manifolds for sale. I also sell the machined Dakota large hole manifolds.
Treblig
