My '68 RR just cut off today
Carolina Carl
7:46 AM
Charlotte, N. C.
Help, my roadrunner has been running great and today for some reason it started cutting out slowly, then picked up and in about 30 seconds completely cut off. Luckily I was able to get it out of traffic. It sat for about 2 minutes then I got it running again and really got down on it and it ran ok back to my home. I waited about 20 minutes and took it around the neighborhood and it ran fine. I did put 7 gallons of ethanol free premiun in it yesterday. It has an MSD system in it and it felt like an ignition problem. One thing it has been doing for a week is when I start it the alternator guage goes nuts, back and forth, until it gets hot then it is ok. I am afraid to take it out. Any help would be great. Thanks Carl
When I restored my 70 Challenger, I upgraded to the mopar performance distributor and orange box controller. My car did the same thing after driving it for a short time, it would shut off and not start again for about 15 minutes. Turns out the orange box was not grounded very good due to too much paint around the mounting screws and the controller would get hot and open the contact inside until it cooled down. I'm wondering if you don't have a poor ground somewhere causing your issues.
The next time it dies, quickly turn the key off, then on again (several times if necessary) as a worn out ignition switch can cause the same symptoms.
Need more detail. Have lights? Start with the Bulkhead connector. Pull apart and spray with electrical cleaner til the can is half empty.
Take the bulkhead connectors on the firewall all off "very carefully" !!
rust & corrosion can wreak havoc in them & they can be very brittle also, take your time...
Clean all the connections very good, use what ever you need to,
to get the connections all clean as possibly !!
I used a little bronze wire brush, a pipe cleaners & a small piece of 220grit sandpaper,
then spray/clean it out {use a aerosol electronics type cleaner that will be residue free}
& make sure to clean all the connections on both side...
Before reinstalling the bulkhead connectors, check them &
use a little dab of Dielectric grease {use it on all electronics & grounds etc.}
use a little dab on each connection terminal...
Absolutely make sure & check your connections & clean them
{use a dab of Dielectric grease on the connections}
when putting them back on the back of the Amp Gauge too,
check the wires going to & from, on the back of the Amp Gauge too,
make sure no cracked wire or burnt connections, that could ground out or short...
Good luck be safe, Bulkhead connections & Amp Gauge issue,
have caused some serious problems on many a Mopar's...
there's a site Mad Enterprises @ http://www.madelectrical.com/
in their electrical tech section they have some great info too...
the Amp Gauges can cause problems...
everything goes thru those bigger black wires under the dash,
that all goes thru the Amp Gauge, runs everything thru that one source....
you can also shorten the path for the charging circuit, ease some of the problems,
with a shorter 12 volt supplied current flow... less path to travel, far less resistance,
charging system will work better,
eases the load with less strain/draw on the under-dash wiring going thru the Amp Gauge...
You can run {add, you don't need to remove/modify any of the OE wire} a 8ga. wire,
from the back of the alternator main output charging terminal the 1/4-20 threaded stud,
run the wire along/with your engine wire harness,
up-to the starter relay on the firewall by the bulkhead connectors, to the large 1/4-20 threaded stud
these will help even if your not having any issues
make sure you have a good/clean
{use Dielectric grease after getting a clean paint free connection, before reassembly} engine to body,
body to chassis & battery to chassis grounds
electronics will seek the shortest path of resistance, you really need good grounds,
good clean grounds will help to save/stave off some faulty old wiring issues,
add or replace grounds if necessary...
good luck & happy Moparing
Great info, my Roadrunner did almost the same thing, lost all electrical power. I took the bulkhead connector apart and it was full of corrosion too. The other problem was, it had over heated over the years and had a melt-down. Now I have to replace the firewall part {when I can find one} then transfer 24 wires to the new one. Thanks for sharing this great info. Mr Budnicks
