dying interior panels from gold to black
Texas charger 73
10:46 PM
Texas
I currently have full gold interior in near perfect condition. I want tongo black since I can't find anyone to trade me straight up I'm lookimgningo dying mine black. Who has done this successfully? Does dying just mean painting? What's the best way to do this? What products I need? Also trim pieces, do I just paint? What color black? Flat,satin,gloss?
Yes it is like painting but the paint is a flexible product. The most important part is to follow the instructions. Make sure the panels are clean and free from any interior dressings(Armor All, etc). I have used SEM products in the past with success. I thinks SEM has some Youtube videos also. Duplicolor makes a similar product.
http://www.tcpglobal.com/Search.html?query=sem+color+coat#/?_=1&page=1
Use this stuff before you paint
SEM has a 3 step vinyl/plastic painting system that works very well (at least it worked well for me....I have used it twice now with no problems so far). There is a cleaner, a "prep" and then the color coat. Just follow the instructions to the letter. And also want to mention that one cannot "dye" vinyl or plastic......has to be painted with a special vinyl/plastic paint system. Stay away from the single step process plastic painting products. The vinyl has to be "prepped" in a way that it will let the paint "bond" with the vinyl/plastic correctly for it to last a long time and not "peal" or come loose from the base vinyl down the road.....If you can practice on a old panel if possible. You have to be careful not to apply to much at once and cause "running" or drips......you will only get one chance to do it right. Good luck.
Thanks. Now I'm scared. I might just do a crap ton of light coats. Where do you find the sems stuff?,kit?
Don't be scared. It's not rocket science.
Light coats are good. You don't want to just pile it on.
Changing from a dark color to a light is harder than going from a light to a dark.
You can buy SEM products from most auto paint supplies. There's a PPG paint place in the small town I live in and they sell it, and can custom mix it as well. Many places online sell the stuff as well. I think even JEG's and Summit may have it as well as ebay.
I have used the adhesion promoter that was mentioned above and it does help but the main thing is just making sure the parts you are going to coat are CLEAN.
I just noticed you posted this topic in 2 places, and I answered you in the other forum before I saw this post... Anyway, here is the info I gave on the other post:
I have done some of this. It's fairly simple. I will say that I have never actually done it to the seat covers themselves because I would think that the possibility for failure of the "dye" would be greatest there due to the flexibility and wear and tear that the seat covers must endure - so I just replace the seat covers in the new desired color. Also, come to think of it, I have never used the stuff on a headliner. I have always just replaced the headliner itself with the new color since headliners are usually deteriorated and it's not worth wasting the "dye" on. The stuff may work fine on those parts as well but I cannot tell you that from personal experience.
The whole "dye" process really is just painting as you mentioned. You are actually just coating your parts in a special paint that is formulated to cover flexible parts specifically but can also be used on hard plastic surfaces and metal trim. Basically you can do your entire interior with the stuff. I've done my dash pad, the dash itself, the door panels, all the plastic kick panels and lower door panels, seat belts, console, metal rear window trim, just about everything in the interior with the exception of the seat covers and headliner as I mentioned.
SEM is the stuff you want to use. To dye your stuff black, you want "SEM Landau Black 15014" - That is the perfect color black.
I buy the stuff by the quart and spray it out using my small HVLP touch up paint gun. You CAN buy the stuff in a spray bomb can and just spray paint it on if you do not have a paint gun and compressor, but I do not know how well the spray paint works.
You will DEFINITELY need to thoroughly clean the parts you are going to paint. I use soapy water, wash the parts and scrub them with a red scotch-brite pad as I am washing. This scuffs up the surface slightly, giving the paint a better surface to stick to, and removes any greasy residue from the part which would resist the paint.
I recently did the interior of my car white. Although my car's interior was originally white, many of the original plastic parts were un-usable so I used a combination of left over black and green plastic interior pieces and just coated them with a custom mix of SEM white. The black pieces (dash, console, seat belts, etc) were done in the SEM Landau Black that I recommended.
This is a pic of the pieces that make up the majority of my interior...
And here is what it all looks like after I used the SEM "dye" paint
Those pics aren't the best but I can tell you that, in person, it looks really good and I feel fine recommending it to you.
I've used the SEM products successfully on my car. The only place where it was an issue was the arm rests. They eventually crack a bit.
Thank you again. Now as far a removing panels. Is that easy or does it take work. I keep seeing all these panel removal tools,are they necessary?, I'm definitely gonna wait till it gets warmer to dye them
You will need some sort of tool to aid in removing the door panels and a few other panels. I use a small, flat, L-shaped prybar.
Just go slow, especially with the upper door panels... If you try to yank those thing out of the door like a wild chimpanzee, you are gonna tear 'em up and they will never fit good again. Just remove all the hardware (screws, handles, etc.from the door panel area) start at a corner, using your tool, easily pry a corner out and work you way up a side, then across the bottom, then up the other side, easing out the clips as you go.
It's not tough to do.
Will i need new clips tonre install or factory hardware re usable? I know like on newer vehicles(especially ford,when you pop door panels you have to buy all new push tabs
I used the SEM products to change my interior from tan to black. Used the Landau Black that Magnes mentioned, painted everything but the seats. I think it came out great. Wear nitrile gloves through the entire process because fingerprints will leave a mark. Cleanliness is the key; I used TSP (tri sodium phosphate) in hot water for the initial cleaning but most any mild detergent will do. Multiple light coats is the way to go - it took three coats for the tan to be completely covered, and then another 2 - 3 coats before I was satisfied with the look. And the ambient air temp should be at least 70* for best adhesion.
On my 69 I was able to reuse all the mounting hardware. Just take your time and you'll be fine. Good luck.
I use SEM Color Coat to paint my rear seats and also sprayed the carpet with it.
