1966 Dodge Charger TLC Project
quatro
3:03 AM
Norway
Got this car in summer 2012. 1966 Dodge Charger 383 with Manual 4 speed transmission. original Black and Gold interrior.
2013-07-08 13.18.41.jpg2013-07-08 13.18.57.jpg2013-07-08 13.20.10.jpgIMG_20130711_174056.jpgIMG_20130711_174254.jpg
Stylin"
Thanks alot! Just adding some more pictures :)
Some Work i have done.
-26" alu Rad
-Pro comp autometer/ Water temperature under dash
-BT Handsfree and speakers
-KYB shocks
-New Bushings and Joints in all suspension
-Thicker Torsion bars ordered, Mopar Performance
-QA1 Dynamic Adjustable Strut Bars ordered
-Re Chromed Front and Rear Bumper
-New Joints and seals on driveshaft
-Pertronix ignitor I and Flametrower I Coil
-NGK V-Power Spark Plugs 3332 and Mopar Performance Ignition Wire Set
-Summit Racing High-volume Water pump
-Hayden Fan Clutches 2747
-Flex-a-lite Standard Rotation Clutch Fans 5718
-Dual Carburetor Return Springs
-Airtex Mechanical Fuel Pumps 267
Some Randome pictures:
VERY nice car buddy!!! I had a 67 and always did like them, put a set of fat ole tires on one of these and they look mean, sounds like this one has some mean already aboard, Love the color combo! Enjoy.....
Thanks Buddy! I have already bought fat Redline tires. I will install them after i finish the suspention upgrade this winter.
very nice thanks for sharing :headbang:
New parts ordered. Will order new Sway bars later!
New parts arrived and welded reinforcement on Control arms
2015-03-28 10.20.01.jpg2015-03-26 17.06.36.jpg2015-03-26 17.04.23.jpg2015-03-26 16.59.48.jpg
That's a sweet charger you got there. I love the first generation chargers I'd like to get one, one of these days there so hard to find in nice shape down here. Maybe after I get the 3 cars I have now done I'll go after one next . Good luck with it . Thanks for sharing
ditto what he said, and looks like Christmas in March at your place! Nice collection of upgrades.
Wife and I are working on "her" 67 Charger and you've given me some additional food for thought.
Keep those pictures of progress coming!
Randy
Thanks all! Finish installing on left side. starting on Right side. The upper control arm is a pain in the ***. the bolts are stuck. used 2 hours to hammer out the bolt using every trick in the book. the other bolt im going to cut out today. adding some pictures.
2015-03-31 00.08.12.jpg2015-03-30 16.59.56.jpg2015-03-30 16.41.32.jpg2015-03-30 16.40.40.jpg2015-03-30 16.33.09.jpg2015-03-30 15.10.13.jpg2015-03-30 14.13.33.jpg2015-03-30 14.06.19.jpg
0.96" also ordered Hellwig 1 3/8 Front tubular sway bar and Summit Racing 7/8" Rear Sway bar...
OK time for some updated pictures.
2015-05-11 13.27.22.jpg2015-05-11 13.27.32.jpg2015-05-13 13.47.20.jpg2015-05-13 14.19.25.jpg
And some more..
2015-05-13 15.55.57.jpg2015-05-13 17.29.32.jpg2015-05-13 17.29.43.jpg2015-05-13 17.29.53.jpg
