mopar 3 B
The big problem would be getting all that safety equipment into the old car and getting NASCAR to allow the extra 300 ponies their running in today's sleds.
Under the hood, a real miracle was taking place. Keith Black's engine shops had kept the 340's 4.04 inch bore but had destroked it to 303.8 cubic inches. Thanks to the special Trans-Am block which had a beefier bottom end, the main bearing web was redrilled for four bolt main caps. A cross drilled crank and forged rods were good to 8,500 RPM and the engine was kept alive with a better oiling system. The new heads were treated to a port job and the valvetrain was beefed up with Hemi rocker arms and shafts. With a single Holley four barrel carburetor, the engine now dyno'ed at over 460 horsepower.
as you can see they are not compatible or interchangeable at all, let alone fit under a SBM valve cover
From the AARchives - some info on the 5 liter build.
http://www.members.shaw.ca/aarcuda/svamcaarta.html
If the #22 car engine was living at 10,000 it must have had even more work done to it, and likely more power as well. My way of thinking - I haven't seen any solid dyno info on it.
I did wonder about that part, I wonder what Kieth Black would be able to tell us.
Photon! I hope i can remember how i did this. 8MA-1148. a 70....was one of 50 USA export cars that had the DOT mandated flip up single beams. Horrid affairs, cable operated and the lock on mine didn't work well...had the lights collapse under cornering pressure a few times so i cut up the boxes and fixed the lights into grille nacelle...a kid..too much brass and mud, but IMO hugely more asthetic than the Lancia style flip ups. OK more will follow after a while if i retrace my steps correctly...i am learning something about comp navigation here. Peace
Couple more of the "Goose" the composite is my 68 Post B- body and the bummer & linkin are two completes idi...the bummer was a roll over...the linkin was just a very tight strip & paint that i spent 2 1/2 mos. with. The chevelle is a cut & polish i did @ Santini's in Westminster, Cali. I've got this thing figured out now.....i have LOT's of pictures of cars, airplanes and aluminum sculpture. I got a 'Goose" pic that otta' put a grin on. L8R Mopes
This pic has been on the web for a while now....somebody pulled it off the mangusta registry pages and imported it into a french car forum.....some frenchie car photoger whining about how tacky it is. Wonder how many miles he put on a mongoose? iioo on clock when i bought her and i added a zero in two years. car's like doin acid...fun, dangerous, can't wait to do it again. So does this validate me Guys? Am i ready for initiation into club? I do have the Mopar RV's....i even got a really healthy 440 BB. jimi
My late Brother Will's builds i helped with some. The Bug is a wolf in wolves clothing...beam front sup gone replaced chrome moly fabbed a arms heim located, spax coilovers, mitchell turn and half loc - loc rack, cross drilled discs all four, 911 5 spd, 2150 w/ Webers yata....this car hauled some ***....windscreen 7" door posts kicked ala chopped merc. Van wind screen was 14"...had to lower dash, slider worked...i'm 5'8" and you can see i'm not standing straight...roofline was less than 6 ft. L8R Boss...i'll take a break for now, but rest assured i will be back with more.
Photon....67 goat i've been involved with...camera dates are off. This is a full frame off rottiserie....extensive fabbing...lowered floor pans fabbed seat mounts...all Hotchkiss heim located fully adhust coilover...6 piston wilwood all4 & 14.5" drilled & ventilatd rotors..Tremev 6 spd,,,the LS-2 is 600 n' changehp w/ 550 lbs torque. many different efforts have gone in...hopefully summer sees color...i'll do the cut and buff and i'm going to do all the stainless, man's got a 100K in. The molded scoop extension is my deal...kitty, kitty.... also if You notice, the scoop is now a FUNCTIONAL scoop. i have done a lot of work on this pup, more to come. The sculpture is hand carved, natural polish, from an aluminum aircraft propeller blade...Hence the name Bladecutter. A translation of skills learned in the trenches. "Aluminations" is the name of that bizniss....a website will get underway sometime this year.
1999 "Flamed"
'the Aluminaughty' 2007
Danatoo + Blade ^ Chalice Y & prop tip slice earrings 2013....picture box just froze. all werx are carved from aluminum a/c propeller blades. The cross is a Memorial to the Best damn Dog Ever, DanaToo December 1995- April 3rd 2010....She wuz Rock n' Roll, my co-pilot. Now i am with DanaLoo.
