What to use for cutting sheetmetal
Coronet 14
4:32 AM
Hudson Florida
Where is the best place to get metal shears. I'm trying to cut up sheetmetal Looking for a good set of hand shears to cut up to 18 gauge. The ones from Lowes and Home Depot are crap. They distort the metal. I got the Nibbler from Eastwood today and broke the blade off already. I want something with long jaws that can reach deep to cut the metal without distortion. Also needs a large handle for good leverage. Thanks
Best place would be an hvac supply house. Get the ones that are around 12" handles. Wiss makes a good pair the jaws are around 3" or so
How about a 4.5" grinder with a "slicer" abrasive disk? Works a lot faster than shears and really doesn't distort the sheeting. Plasma cutters work great too...
I agree 110%........Plasma Cutter! By far the way to go. Unfortunately you'll need an air compressor and nice dry air coming from that compressor. Plus, they're pricey. Otherwise, cutting disc on a grinder or die grinder like mentioned, will do the trick. Air saw's work decent, unless the metal is loose and flopping around.
I've used a jigsaw with a fine tooth blade if the metal isn't flopping around. Good for different shapes.
I'm gonna go to Harbor Frieght later this week. I would love a Plasma cutter but I would have to donate a Kidney at this time. Thanks guys
get a electric cut off tool with a pack of 4 inch wheels for under 40 bucks at harbor
it goes a little slower then a air one, but no compressor is needed..
Harbor Freight has a circular saw 7 1/4" metal cutting blade, I have cut 1/2" bolts off with one and work well on thin sheet metal as well.
You can also get a cutting tool for an air chisel it does prity good (cheap at harbour frate), I used a grinder with cut off disc (elc) I used to use air but I got sick of useing all the air and then haveing to take a brake .
Be careful with those cut off wheels in a 4 1/2" grinder. I had a wheel come apart and part of it stuck into my garage door 15 ft away! Glad it wasn't stuck in me!!!..............................MO
I like 6" cut off wheels on a 4 1/2" grinder myself.
Same here. I use 4-1/2" and 6" cut offs (the .045 thick versions). They're the most versatile and affordable tool for doing sheet metal. Plasma cutter is convenient but expensive and leaves a cut edge that requires dressing prior to welding. Shears distort the metal no matter how nice they are.
Agreed
I love using my dewalt jigsaw with a fine-tooth metal cutting blade. Cuts perfectly, with zero distortion, and goes through metal like butter!!!
