Fan Blower Switch
BubbaMope
8:12 PM
Louisiana
I have a 1970 Belvedere 318 Factory A/C car. The blower switch works in all positions but high. I'm not sure how to troubleshoot if it is the switch or the blower motor but logic tells me it is the switch. Can the switch be fixed or does it have to be replaced?
I've been searching and searching the Mopar vendors, can you buy this fan speed resistor new somewhere?
On the heater box there is a resistor that controls fan speeds, looks something like this. Swapping this part should fix it. Good Luck http://www.americanpartsdepot.com/images/N322 4862.JPG
AND has anyone used this specific AMC resistor part in their Mopar? I want to order it, but since its like $75 and non-returnable, I want to make sure this will work for a Mopar.
You can test to see if all three of your resistors are good, they should measure 0.2, 0.4 and 0.8 Ohms (plus any meter lead resistance). They look like coils of wire. The unit probably has a switch on the right near the vacuum cans. It is a bypass switch. This switch shorts out the 0.2 Ohm resistor when one of the linkages is in the right position.
BTW: MyMopar reference section has a description in 1969 AC Controls section. The PDF page 12 zeroes in on the blower controls and resistor.
See: http://www.mymopar.com/index.php?pid=446
By the way: The 1967 service manual, and perhaps some others, appears to be drawn badly wrong in the specific area of the blower switch and resistor.
