318 out 440 in. Mount questions
TomH
12:02 PM
Canada
Swapping out a318 and putting in 440. Are engine and trans mounts the same or do I need to change them? 67 Coronet 500. Floor shift automatic with power steering. The 318 and 727 are original to the car.
TomH
E-mail, wthibb@gmail.com
pretty sure the 440 will need big block engine mount brackets.
Yep! You'll need the engine brackets and insulators for the big block! 66-67 style trans. mount shouldn't be a problem!
Motor Mounts on the K Member are the same for the 318, 383, 400, 440. I bolted up a 383 into my '66 Satellite with no problems...cr8crshr/Tuck
The motor mount 'stands' on the K frame will accept any V8 other than a Hemi. The rubber insulators are also the same but the brackets from the block to the insulators are not the same.
