2892513 Bellhousing fit a 69 coronet
8:47 AM
New york
Looking to switch from a automatic to a 4speed.I'm looking to buy a bellhousing for my 69 coronet with a 440 motor,i see there are two types of bellhousing found code # 2892513 and 2892626 is there any difference between the both of them?and will both of them work on the car.
Either will work as long as you have the right flywheel and pivot to match. 626 is for a 11 inch setup.
From Brewers, looks like 626 is specific to 69 and 513 to 70-72
"Reconditioned original 11" big block bellhousing to fit 383-440 1969 B-body (3 or 4-speed), cast #2892626, 4.805" bearing retainer diameter, use with 143 tooth flywheel."
"Reconditioned original 10.5" big block aluminum bellhousing to fit 1970-72 383/440/426 HEMI B & E-Body applications, cast #2892513, 4.805" bearing retainer diameter, use with 130 tooth flywheel. "
Either will work if he is not looking for matching numbers. Each needs the right size flywheel, clutch, ETC...
