- 11:28 PM
- Apr 13, 2012
- Granite Bay CA
We have been lied to.
We have been told for years that big torsion bars will make your car ride like a unloaded dump truck, rattling the fillings from your teeth. The Mopar Performance chassis book listed the 1.0 bars for 62-72 B bodies as being for serious autocross & competition. I took the advice in 2001 and have had them in my 70 Charger until last week.
Recap:
70 Charger R/T clone. 440/493 with aluminum heads, radiator, intake, TTI headers and the battery in the trunk. The front end might carry as much weight as it did with the original all iron 318. 1.0 MP torsion bars, 1.25 solid anti sway bar, Offset UCA bushings, Firm Feel stage 3 with FR arms. 8.75 rear, MP XHD springs, 7/8" ADDCO axle hung rear anti sway bar KYB shocks front and rear.
The car rode okay but was a bit harsh on bumpy roads. It had an oversteer tendency that got worse with increased speed. I tried running the car without the rear bar. It didn't oversteer any more but the body roll increased to the point that it annoyed me. The traditional "fix" for this has been well documented: To reduce UNDERsteer, the rear spring rate needs to be increased or the front decreased. To reduce OVERsteer, the front spring rate needs to be increased or the rear decreased. Now to achieve an increase, it can be done with either a spring change or a stiffer anti-sway bar. I already have about as big of a sway bar that can fit through the K member, so I was left with the option of bigger torsion bars.
For years I have read that the big bars will make the car feel too harsh. The factory was notoriously soft with their rates though. The stock bars in my Charger were .88 so the change to 1.0 seemed big. I installed the KYBs at the same time so it seemed like a big improvement. In the years since, there has been a change in the tide. There are more web forums now than in 2001, many with subforums catering to improved handling. I have never been a drag race type guy. I love to turn corners!
In the effort to get a neutral handling car that doesn't try to hang the tail end out, I first went with a smaller rear sway bar. I saw one in an 83 Imperial that looked like it would fit. The frame rails were the same distance apart. After installation, the car felt a bit better but still not right. I ordered a set or 1.15 Torsion bars from Bergman Auto Craft in NY along with a set of Bilstein shocks from Firm Feel.
Over the last 2 years I have wanted to change to the Bilsteins. I've read bad reviews about KYB shocks but didn't know firsthand what a difference the Bilsteins would make. The KYBs were touted as being too stiff. Seems like that is a good thing until I read more. Apparantly, they are a digressive design that is initially stiff but get softer through the range of travel. This means that as you get more aggressive in the turns, (JUST when they need to get working) they go soft. The Bilsteins are the opposite. They soak up the small bumps allowing suspension movement, but get firmer as the suspension travels more. THIS makes so much more sense, right?
The car feels absolutely awesome to me now. The ride is no firmer than our 2015 Challenger R/T. No brake dive. Fast response. NO oversteer at all. I crank it into a turn and the car just sticks to the road. NO harsh feel, just a firm ride without beating me up. The bars are on sale for $275 and they have 3 sizes to choose from. Check it out!
Recap:
