DutchGuy
Hello,
I finished the replacement the wiring harness of my wife's 1972 Charger SE. I picked up a serviceable Rallye gauge cluster and would like to swap the standard "sweep" cluster out. However, two things are missing. The Rallye cluster has the light switch but is missing the wiper switch. Will the one from the standard cluster work?
More importantly, the back of the cluster seems to be significantly different. The standard cluster has a cuircuit board with a large connector (pins in circular pattern). The Rallye cluster has no circuit board but uses individual posts for each gauge. While I can figure out what goes where I'm lost regarding the cluster lights. The twist-lock sockets with the T3 1/4" wedge bulbs from the standard cluster obviously do not work. The manual says the Rallye cluster uses type G4 (1/2 BA9S) bulbs but what do the sockets look like?
Does anyone have a pic of one, or better still, a lead on where to get them?
thanks
W
thanks
W
