Does this piece look familiar to anybody?
hunt2elk
7:34 AM
WI
I found it on the floor after removing the axles and third member from my Road Runner. It is .0185 thick with about a 2 3/16 outside diameter. I am stumped as to what it could be for.
It is metal. The weird thing is that I had just replaced the axle bearings and seals when I rebuilt the rear end. Drove it about 100 miles. Had a howl in the rear, so I took it all apart again and that's when I noticed this on the floor under the passenger side. I suppose it could have come from something else, but I always sweep the floor up after a project is done.
if that is the snap ring off the axle bearing you need to fix it before the axle comes out
No green bearings, replaced the originals with the original cone style. Any other ideas?
what kind of wheels do you have ? some type of snap ring for the center cap ??
Crager SS. Don't remember there being anything like this in the center caps, but I will check.
these look like they have a ring ?
maybe not LOL
It has a funny tab facing the ID. Never seen that before so probably not a bearing part. And at .018" thick that's not likely anyway. Wheel center cap is a good guess.
