DWilbur
I bought this A904 trans mission through Summit Racing back in November. Meanwhile I was building my stroker engine 318 to 390. About 3 weeks ago I finally was able to fire up my engine 2 minutes and 34 second in to the run trans fluid was pouring out of the bell housing. so we shut it down raised the car up 1973 Plymouth Satellite Seabring Plus. Ended up pulling the trans mission after removing the torque converter we noticed that the front was galled up. I called TCI and they asked several question over email and do to the warranty being 90 day they said there is not much they can due. the other thing that came up was the horse power would toast the trans mission. I said the add when I bought it said it would handle 575 HP. TCI said it will only handle 350 HP. TCI ask where I saw the add I said Summit. He said call Summit and see what they would do. 3 days went by do to work and when I called Summit they said there add does not recommend HP rating. while on the phone with Summit I check the add and it was changed. So no Warranty. Saturday we removed the front seal to install a new one and the front bearing was wasted. Now I have a $1,250 paper weight.
So my question is I would like to Xna the A904 and install a 727 trans. What would be a good place to get one I have call some local trans shops and they don't have much of a clue as to how to build an 727 to handle 450HP small block Mopar. I need to get my car running ASAP as I need to fix my 98 Ram has radiator and valve cover leaks. I will post pictures Tuesday so you can see what the issues are.
