3 speed wiper conversion
jimm69
11:37 AM
ohio
I plan to install air grabber setup on my 69 Roadrunner so I swapped out my 2 speed wiper motor for a 3 speed unit. Bought new wiring harness under hood so everything plugs in as it should. I was told that if I bought the correct 3 speed wiper switch that it would plug right into my existing wiring. Plugs are not the same. Did someone sell me the wrong part or did I get incorrect information as to the interchangability? Is there some sort of adapter or do I just have the wrong switch?
Did you change out the crank arm? It's different than the two speed.
yes, I did change that. that was a pretty hard item to find. I am just confused about the wiring.
I would contact passionformopar on this site. Kim is an expert in this area and can give you any info you need.
Jim,
I did the swap on my bee it's been a while but I don't remember having a problem with the harness plugging in to the 3 speed switch.
I agree with calling Kim, but I heard the same thing about the wiring as you.
wiring harness should be the same, i converted mine to a 3 speed and the switch plugged right in. as i recall the back of the switch is different though and used different parts of the connector than the 2 speed.
did you use all the terminals on the back of the switch?
As I recall something looked funny with it, thinking there was terminals on the connector that were not used. May have been one on the switch.
Thanks everyone. I think I have it figured out
Well do tell, I have a cars one with a 2 speed and one a 3 speed, trying to figure out which one goes in the "final solution"
if you switch the motor, you definitely have to switch the crank arm or the wiper will not park correctly. What I found with the wiring is that the wiring is there for the 3 speed switch. I plugged in what I think are the correct terminals. I do not have power to the car yet so I do not know yet if it is wired correctly, but hoping to do so within the next couple of weeks.
OK, so the wiring should be there for a 3-speed motor.
I wonder if the the transmission linkage is the same between a 2-speed and 3-speed
