Warhorse
Ok, I haven't found a topic on this but it's gotta be in here somewhere. I'm having a bad fuel sending unit experience. I have just about finished the restoration of my '68 Charger, with just trim and stuff to go and I've had her out on the road for a shakedown drive already. My sending unit issue began when I added fuel for the first time. I put in 10-gal of Av Gas and a leak around the sending unit locking mount ring began immediately. I siphoned the fuel out, dropped the tank and found the locking mount ring completely loose. Note that someone else actually installed the fuel system. What I discovered was that the locking ring was a very cheaply made stamped piece that didn't even fit the locking ring wrench tool properly. The locking ring was too thin as well. I found two locking rings available at Classic Industries: one was this same cheap part I have: Part# MF291 "Stainless steel" and the other is an OEM type Part# MF292 "Zinc." This latter piece is the correct piece, stay away from the other one. Note that the correct piece costs $5 more. I installed this correct piece along with the original gasket and it tightened nicely using the locking ring wrench. I had a good leak check and installed the tank. I poured in the rest of the fuel and started the engine: now the fuel gauge registers just a tick above empty (should be over 1/2 tank). In what could be another forum subject, I fabricated a test box using an original gauge cluster plug and tested the fuel gauge on the bench and it tests good: 73-ohms FULL/10-ohms EMPTY (per the manual), so the fuel gauge is good. I measure 50-ohms at the cluster plug going back thru the wiring and sending unit; I would expect around 30-ohms for 1/2 tank. Dang, looks like a bad sending unit! After my experience with the cheap locking ring and some other "cheap" parts I've run into along this resto journey, I'm wondering if I have a "cheap" sending unit that is not worth its weight in tin. Has anyone else run into crappy sending units? Are there ones that can be recommended?
thanx...
thanx...
