Engine, clutch, and tranny
Next thing on the list was to get the engine ready. The tin foil is masking for the timeing chain as I painted the cover separately.
The A833 4 speed was inspected and in excellent condition. Installed new seals and gaskets
I bought a new Flywheel from 440 Source. It can be used for internal or external balance. The Centerforce Dual Friction clutch came from Mancinni. To be sure of correct clutch linkage geometry, I purchased parts I needed and trans. oil from Brewers Performance.
The engine with bellhouse and clutch assembly went in very easily with the Schummacker motor mounts. Had to be easy cause I did it with no help!
The 742 with shure grip and new 3:55gears all rebuilt, were bought from a guy on E-Bay who regularly sells Mopar rear ends. I don.t recall his name, but I was very pleased with his work. I used a 1965 axle housing with all new big rear drum brakes
When I got the Dodge running under it's own power I took it to my body man to get dents out of it. primer, and paint the door jambs and the inside of the trunk lid. The fenders and doors were done separately After I got the Dodge back home, I installed them
After I got the doors and fenders on, I took it back to the body shop for alighnment of the panels and finish sanding . That was about the first of Sept. but due to circumstances, did not get painted till last week. That brings us up to date. Color sand and buff and then Brutus will come back home!!..................................MO
