green 66
Finally fixing trans pan gasket leak.Dropped pan and found shavings on bottom of pan and on filter.Seems the tail-shaft bearing has alot of play,can hear it about 3/4 of the way up the tail-shaft.Going to pull the tail shaft and try to replace the bearing.Anybody know where i can get the bearing and the 2 seals? Thanks
