Any source for this headlight switch connector new??
A383Wing
4:11 PM
Somewhere
Looking for this headlight switch connector plug....someone has to make them.....
anyone know where?
It's rebuildable, what is the problem with it?
how do you rebuild one if all the plastic is melted? Which is why I'm asking where can one buy these new? Someone has to make these for all the new dash harness's that are being sold.
This is odd but the picture of this connector from Parts Geek looks exactly like and early model connector but it says it's for a late model Mopar. You might give them a call.
http://www.partsgeek.com/hg2h8vh-ch...ard+motor+products+headlight+switch+connector.
Will have to see if it will connect to our headlight switches.....thanks
Doesn't look melted in the pics but a new one would come with a new harness. I have searched for a few years now for one of those, a ignition switch & cluster connector. Even slightly broken I was able to rebuild them with new connectors.
All I asked was where to buy this connector, if all you want to do is argue about my picture I posted as to what I want, go bother someone else...you are contributing nothing to this thread
Fine **** u then good luck with ur ******* connector asshole.
I'm pretty sure those connectors are the same all the way into the 80's M bodies and even late 80's trucks.
The headlight switch in my 86 5th Ave and 87 D1500 look identical as far as the actual switch and connectors go.
Just the knob and fascia are different.
exactly, which brings me back to the question if all these dash harness's are being reproduced, where can one just get the headlight plug? That one from Parts-geek has more terminal connections than my 66 has....it might fit, but then again, it might not
